buzz noise 3000 rpm
thprcz
6 participants
buzz noise 3000 rpm
Hello all, sorry for English language, i don't understand Frenc. When i'm driving (or neutral, park car) my rcz (2011, 200HP) around 2800-3000 rpm i hear annoying (buzzing) sound around the air filter :thumbdown: :? has anyone had a similar problem? I tighten all bolts, replace rubber holders for filter, checkeh exhaust leak, exhaust shield, sound resonator and there is nothing better.
https://www.youtube.com/watch?v=SBuaD2GYvR4
thprcz- RCZ Stagiaire
Re: buzz noise 3000 rpm
welcome with us
where are you from?
I listened to your video
sounds to be a vibration
did you go already to au Peugeot garage?
where are you from?
Jack Reacher- RCZ Confirmé
Welcome,
It could be the "the turbo heat shield plate"
I think it's a vibration too
Good luck to find the source
I coming from Slovenia. Peugeot garage say that is normal.
I remove turbo heat shield plate but nothing is better.
Hello, it can come from the sound system itself just take a look a it. it's a vibration amplifier membrane between the air intake system and the fresh air intake for the clim system. Number 11 on the data part sheet link below :
I cheked this piece. in this part is a small plastic part, which i tried to remove, but sound is still there.
do you loose power engine while driving?
You may have punctures the membrane between the two circuits, but in this case you will loose power by the leak of pressurized air from the intake system.
Car runs fine, without any problem. The problem is only this annoying buzz sound.
Menvick57
Do you think the punctures in this part?
Menvick57
Wolfe-red- RCZ Professionel
kikine- RCZ Expert
thprcz a écrit:Car runs fine, without any problem. The problem is only this annoying buzz sound.
Menvick57
May be, you can easily remove the sound system pipe that drive the noise into the habitacle to see if it come from there or if it's an other piece Inside the Dashboard the go in vibration when the engin run at 3.000 rpm.
